seriously, i thought it was simple question.
It
was a simple question (both your questions were simple questions) - people are just getting a bit silly/'clever'/'teasing' because you used the wrong units.
Taking the important, second, question first - the first two responses you got gave you an answer. If the 15kW heater is on 'full' continuusly (i.e. not being switched on and off by a thermostat) then, if one assumes a commercial cost of about 10p per unit, then the 15 kW heater will cost about £1.50 per hour to run.
As for your first question, a 15 kW heater (again, assuming it runs continuously at 'full blast') will consume 15
kWh (kilowatt-hours), aka 15 'units', every hour (
not "15
kW per hour" as you wrote, which is what resulted in all the 'teasing').
It that clearer, or simpler?
Kind Regards, John
