I am planning to put underfloor electric heating in Kitchen (8m2 - 1120watt) which seems fairly straight forward with my current DIY skills.
Just need to confirm if I can run the power to electric heating (using thermostat) via 3 pin plug in one of the available socket in the kitchen without breaking regulation?
Whole house power circuit is fronted by RCD in the consumer unit and I read in the instructions that thermostat should have double pole switch in front.
So rather than messing around with a complete new wiring from consumer unit or running internal wiring spur from power socket and putting double pole swich, easiest option I can find is to run a simple 2.5mm cable up using 3 pin socket (with 13A fuse) to the thermostat and leave the power switch on all the time.
Of course that cable will be visible which I can easily run it through behind the plaster board as well
Do you see any problem with regulations / risks etc for this?
It's wooden flooring in kitchen and there may be accidental spill of water ... just wondering do I need additional RCD in front? Guess not .. as the whole circuit has RCD in consumer unit.
