The hot water from the taps? If so, you'd have to adjust the thermostatic mixing valve, the 3-port valve at the top right of your picture. The ones fitted to the Powermax frequently fail, so adjustment may not work.
That's it. The black knob is an anti-tamper device. Undo the screw, remove the black knob and there is a square adjuster under it. Rotate the adjuster clockwise with an adjustable wrench or the right-sized spanner, if you have it. Re-fit black knob on completion. The outlet temperature shouldn't be below 55-60degC.
If it has gone out of adjustment, I'd suspect that adjustment may make no difference, in which case a new TMV would be required.
