Prefered way to install ceiling lights
13 Jan 2012
Blackpool
There's an old saying that if you should ask 10 cooks how to poach an egg, then you'll get 33 different answers. In a similar arrangement, there seems to be many and varied solutions to powering a light fitting. Let's start by removing the ye olde ceiling rose from the equation, as it doesn't compliment the light in question. I guess that leaves pulling a bundle of cables through the ceiling and attempting to choc block the lot in the lack of space available or terminating it inside a maintenance free junction box in the ceiling void? So, in summary: how do people prefer to wire their lights these days?
Also depends on how the circuit is wired.
Might only be a single cable at the light position. Ideally a 3 core + earth.
I choose the must logic/practical method that suits the situation.
Sometimes loop in at ceiling, sometimes at switch, horse for courses.
Loop-in at the switch is the preferred way for me nowadays for new work, as non-ceiling rose lights can be awkward so fewer cables are desirable. Since deeper switch boxes are fitted now to allow for dimmers, there's room to loop-in at the switch.
On regular domestic rewires, I prefer to loop-in at the light, as the existing switch conduits are narrow.
Many installations will be a combination of both methods, sometimes with junction box method as well.
