Premier Elite 24 add new sensor without bell ringing
24 Jan 2020
I'm adding some additional sensors to my alarm system. As expected, when I remove mains from the panel then disconnect the battery, the bell rings. I can disable the bell from ringing by setting an internal jumper on the bell temporarily, but, this involves going up a ladder and the associated faff.
Maybe I'm just being lazy, but, is it possible to add a sensor without setting a jumper in the bell and without triggering the bell?
Thanks,
Phil
It's a Reson8 Bell Box. I'm setting the "battery off" jumper to prevent the bell from sounding.
I'm powering the control panel down so I can wire in additional sensors. Is it ok to wire in sensors with the control panel powered up?
I'd rather short the pcb than fall off a ladder, so I'll add them live, albeit carefully.
Thanks for the advice!
