I have a Glowworm 30 sxi boiler, a few days ago the heating wouldn't fire up, the pressure had dropped to 0.6 and was flashing on the screen. I topped up the pressure using the filling loop and the heating came back on. Next day same problem, the pressure had again dropped to 0.6 and after filling it up via the loop it started working again until the next day same problem etc...
I've checked under the boiler itself, I can't see any leaks, there are no obvious leaks around the radiators or in the house. The boiler pressure relief pipe outside is dripping, it's worse after the pressure is topped back up, I top it up to about 2.0 bar.
From what I've read on the net it could be the pressure relief valve that needs replacing, does this sound about right? Is there anything else it might be? Is it a DIY job to drain the system, replace the valve and fill it back up again or should I be seeking a professional?
Thanks.
Thanks.
