Prestex P 404 TMV 2
SMG
31 Oct 2007
Manchester
Can I use 1 thermostatic mixing valve to feed 3 sinks? Or do I have to fit 1 per sink?
TiA
it will "work" fine, I would recommend a 22mm TMV. I don't know where its for though, so just be aware that Schools, hospitals and some other commercial situations may have specific regulations.
Thanks, its a private house, (Mine) to feed the sink & 1 wash hand basin. Both fed by 15mm copper, both sinks using flexible tails at the tap. Hot & cold on mains, 3 bar.
The sink, as in kitchen sink? Are you sure you want to restrict it's temperature?
Yes m8, it just dawned on me that the system runs between 60 / 65 degrees, problem solved, kitchen sink doesn't really need one. Thanks.
