Hello,
I am in the process of renovating a house and the existing internal render is just falling off the walls. A builder I know says it is because they used to use lime in the render and that is contributing to the failure.
Rather than 'bodge' it I am going to chip all of the existing render off and replace it. I was thinking of improving the insulation at the same time and replacing the render with Thermaline Plus insulated plasterboard on the internal face of the external walls.
I am thinking of hiding the central heating pipes (which are being replaced too) behind the plasterboard by notching out the insulation.
My question is, as the pipes will be behind the plasterboard and I have notched out the vapour control provided by the polystyrene, will I have to do anything to prevent a damp problem caused by the heat from the central heating pipes.
Many thanks in advance.
