I'm trying to replace a dimmer switch with a standard switch. The dimmer made a loud humming noise, and the lights (halogen) flickered badly. However i can not get the new switch to work with this fitting (i have tested it works on others).
I think it's down to my wiring, so please help if you can.
There is only a single light, although there has always been 2 switches on the fitting. There are 3 red wires and a black wire (it has an extension plug on it and not currently connected). Basically I can't get any combination of the three red wires to work, although the dimmer switch does operate as described.
The switch has 2 fittings L1, L2 and common on both.
