Problem Tap
8 Feb 2006
Lanarkshire
Hi Everybody
Can anyone help me?
My friend has a problem with a bathroom sink hot water tap.
It seem she can't get the tap to turn much and is only getting a small trickle of water from it.
All of the other bathroom taps are working fine.
Does anyone have any suggestions on what might be the problem.
Thanks for looking :D
chicklet said:
Hi Everybody
Can anyone help me?
Try turning the shaving mirror to face the Northern side, then stand on your head & pray to the God "EEZAVINALAFF" do this thirty times a day for at least 6 months & your problem will be solved.
Either that or get a plumber to renew the washer in your tap.
Remove the tap head and then the bell shaped cover with any luck you may see a circlip has dislodged itself from the stem ,refit and normal sevice should be resumed.
chicklet said:
Petetheleak, Thanks for the advice. will try that first.
Bambergaspipe - why bother!!!!!!
I already solved your problem :cry: Why you wanna Dis me :roll:
True you did Bamber, though you missed this :lol: or this :wink: at the end, so OP did'nt understand your humour :shock: :wink:
