Problem with filler - not strong enough
OM2
18 Jan 2007
I've got a long curtain pole that has fallen off.
I've filled in with this wall filler I bought from Amazon:
PROBLEM: the curtain pole falls off again.
The filler that came out was brittle and not hard.
What am I doing wrong?
The filler is 'supposed' to be strong enough to be re-drilled and hold strong and be crack resistant.
I'm just adding water to the powder.
Hoping there's a quick answer. Happy to get alternative filler or adjust the formula for this current one I have.
Thanks.
Expecting filler to hold up a curtain pole.
You need to drill through the filler and the plaster into the wall behind, hopefully brick or block, and insert a plug and a screw long enough to pass the load about 2 inches into it
No... it was into brick. No plasterboard.
I thought this filler would be OK?
Still not sure what I should be doing
Have you got a drill?
How far under the surface is the brick?
How deep did your plasplug penetrate?
How deep did your screw penetrate?
It is no good screwing into the filler.
@JohnD Yes, I've got a drill. The wall is an outside one, not internal. On top there is plaster.
How far? How deep did your screw penetrate? I'd say 3-4CM.
I guess that's where I'm going wrong :)
It says on the box can be drilled. What should I use instead? I'd like to redrill in the same location. I could move location... but would prefer not to.
Let me know.
Thanks.
I'd say 3-4CM.
That seems awfully thick plaster? You need to drill the brick or block - beneath the plaster, to a depth of 30 plus mm, then insert the plug into that depth and use a screw just a little short of the hole depth - in brick + plaster + bracket.
You drill through the plaster and into the brick. You can drill in the same place, but deeper, unless it is cratered or crumbly.
Disregard the thickness of filler and plaster, it has no strength, so only the depth of plug and screw in the brickwork will provide support.
A curtain pole shouldn't mind too much if its moved left or right or up or down by a couple of centimetres to give a fresh location for the hole.
Maybe it is strong. But the powdery/crumbly plasterboard the filler sitting in is not. Even if the filler doesn't fail, the plasterboard around it will when the filler is under load.
I'm confused.
Surely there must be some sort of filler I can fill with?
I looked on youtube.
One guy used a cement filler to fill holes on an outside wall (I think that's what he used - he seemed to be knowing what he was doing).
The plasterboard is maybe less than a CM thick, the rest is brick I'm sure.
What would one use to fill a hole in a brick wall?
Filler will fill a hole, so it looks nice, for decoration.
But you want a strong mechanical fixing that will carry the weight of a curtain and pole.
Not the same thing.
I recommend filling brick wall using the following filler because it says it's for exterior use. The brick wall provides a strong foundation for the filler. Therefore the fill will work. A plaster board does not give a strong foundation. Therefore the fill will fail when load is exerted.
For my own DIY, I would filled a hole in brick wall using mortar mix (3 part sand and 1 part cement) because it's cheaper, and I have the materials already.
I thought you already have the filler? Just use that. Your local B&Q/Wicks will have ready mixed filler tubs.
