Problem with Neff conventional oven not heating up
17 Apr 2011
UK
Hi all,
Had an odd electrical/burning sort of smell from a Neff conventional oven recently, went on for maybe 3 or 4 weeks with the oven working fine.
But now the oven no longer heats up.
It is an oven / grill (the grill still works), and it has a Neff fan oven below. It is just the top conventional oven that no longer heats up.
Does anyone know how these ovens work and what is likely to be the problem?
Haven't looked yet, but there is a panel at the back of the oven, is there likely to be an element behind there? Will open it and check when I get a chance to see what is there
Thanks!
Sounds like the element. If so it is really easy to change. If you unscrew that panel you will see the element. Mine was out of shape and had a bulge where it had blown. The element is held in with a few further screws. The wires attach with spade terminals. Tie a piece of string round the cables and tie the other end to the door hinge or something. If they fall through the hole you have to pull the cooker out to retrieve them. Ease the terminals off with pliers.
Reverse the procedure to put it back.
I bought mine from http://www.ransomspares.co.uk/. It was only around £15 and arrived quickly. My cooker had no model number on the front so I rang them up and they identified which one I wanted. They also have a video showing what you need to do.
Nice company
Thank you for the details
I removed that panel and, very oddly, there was absolutely nothing behind it, not even an empty space, just a gap of maybe 2mm - 3mm then the back of the oven
An electrician friend told me it is likely to be behind the oven which means removing it from the unit. I've found out how to remove it but it seems to be heating up okay, just checked it the other day
Odd.
If the problem reoccurs I'll take a look
