We have this boiler and a while ago it was failing to start and giving of a loud rattle. I had a look around and the rattle was coming from the pcb...so I bought a new pcb and fitted it.
The rattle was gone and it was trying to start....but now fuses are blowing both on the pcb and once on the actual mains power!
I disconnected the pump and tried it, fuse still blew.
I wired the pump back up and disconnected the pressure switch(two purple wires?) and power goes to everything fine and the fuse doesn't blow. The control unit lights up and works fine ONLY when that is disconnected.
I'm assuming it's got to be the pressure switch. I'm struggling to see how I can change it myself and the exact model I'm after.
This part?
This part?
