Hi
I've got a Candy CM462, wich was put on a normal 30C wash, which got stuck on the first wash cycle, and the water became boiling hot.
Now if i put it on a normal wash, it just stays on the initial wash cycle, for as long as it is switched on, last time about 2 hours.
If i put it on a fast wash, it will run through all the cycles, i.e. wash, rinse and spin, but it doesn't heat the water.
Also it doesn't appear to be flashing up any fault codes. Any ideas greatly appreciated.
