Problem where some radiators do not get hot on system with Worcester CBi 19/24? heat only boiler.
Thermal store has 2 pumps one for primary and one for ch with by-pass valve fitted.
Checked offending rads- trv's fitted but valves checked and no evidence of sticking or blockages (ptfe etc) Some debris in system.
Rads supplied by 10mm hep pipe.
Tried balancing system.Then tried shutting all other rads to force through.
Both in and out tails get warm but rads don't.
tried re-setting by-pass to no avail.
Upped pump speed to 3 (max)on ch pump also checked flow direction away from store.
Then noticed leak in boiler casing. On further inspection cast iron heat exchanger appears to be leaking.(Burst)
Have I done this by upping pump speed?
