As I understand it, the room stat should be located within the coldest part of the house, normally the hallway.
However, am I right in saying, when installing room stats in multi storey flats which have small hallways and communal corridor’s, the room stat should be installed within the largest coldest room, normally the living room. Reason being the build -up of heat in the confined hallway will turn off the room statand the heating.
Are there any regulations under Part L that mention the correct location of room stats? And if so could some kind gent provide a link.
