I went to this boiler last and it was completly dead , nothing on the display , pump not running or fan , main pcb was burnt out ( the transformer ) new pcb ordered and fitted , now the display comes on and the pump runs but nothing else happens , fan doesnt run , +volts to the fan but no neutral , spoke to technical help who went through testing for voltages etc and he was convinced that the ignition pcb had gone and had caused the main pcb to blow as well , new ignition board ordered and fitted and it is still the same ,ie no fan runs and thus nothing else happens , I am now in the place of was the replacement main pcb faulty as the boiler worked fine before that board blew . ld have sorted it Any help greatly appreciated as this is well getting on my nerves cause replacing the main pcb should have sorted this out .
