I used to really enjoy plugging in/pulling out tap-off boxes on 1200A fused busbars
No worse than this piece of equipment just a couple of feet from the road, next to a bus stop and a Royal Mail storage box.Also a car accident could wipe out the power for an entire street.
Maybe he would but then he is hardly unbiased.As regards the PPE the meter inspector that was hospitalised in the 90's would agree to the use of it and the user being trained and qualified to interfere with a DNO main fuse.
The one he was working on looked fine until it exploded in his face
very little quantitative risk assessment is done
I can find out but in non quantitative terms it is the only serious incident I can recall after 38 years with essentially the same company in the industry.
So in those terms the risk of it occurring is very low or low, the seriousness of the incident if it does is however high. This would put it in the level of requiring some precautions in most risk assessment techniques
training or equipment
marigolds, a sthil chainsaw facemask and wearing wellies,
Would come under the risk reduction part of any RA.
There are other precautions that a trained employee of a DNO would be taking.
westie101";p="1853766 said:There are other precautions that a trained employee of a DNO would be taking.
or would have been trained to take.
Had a service alterartion done just before christmas the engineer just waltzed in pulled the main fuse holder (load still on) and that was that.
No precautions no protective gear nothing.
What is that thing?
Having seen DNO MAIN FUSES (Cut Outs or Cablehead in modern speak) Break up when the fuse is pulled and also seen the damage a faulted one can do PLEASE take notice of the warnings the chaps on here are posting....The only protection is the 315A fuse at the local S/S and even then is some areas it may have an infeed at both ends....Iven the best Jointers treat older cutouts with the utmost respect.....
I take it the modern ones dont pose anywhere near as much of a problem then, without a load across it?
I believe they are less likely to cause a problem. But accidents happen.
And a 72.45 Kwatt roman candle as the ancient lead and paper cable burns itself down the wall is spectacular. They don't last long as the network fuse will melt out, eventually.. ( 72.45 Kwatt = 315Amps @ 230 volts )
If you are some distance from the network fuse the candle has less power due to the volt drop along the network cable but might burn longer .
