Drained heating down to do some work on heating, when filling had air locks on heating side ok now but there is now no hot water being heated by 1"preimres.
Can any one help me
could be on gravity or even primatic.
a temporay over heat could probaly fix situation.but who knows when to switch boiler off when doing this.kevplumb does so do i but others will wait until pipes are jumping out of their clips and expansion tank melting.
i would reccomend system drained out again and refill slowly.or back filling again only experienced folk should do this.
Or you could leave the C/H on overnight, it might clear itself. I had one & tried for over an hour to clear the airlock including boiling it in to submision. Gave up in the end as it was getting late, when I went back the next morning it had cleared itself overnight.
