It wasn't the 'royal we' - all of the professionals posting on this topic have access to all of the available appliance manuals. And yet you quote bits of the Puma 80 manual as if you're educating us. It's laughable.
The fault - poor hot water temperature when on hot water only.
The fix - reduce the flow rate by altering the MFR.
The boiler is 11 year old, we moved in to the house 18months ago, most of the adjacent houses have had boiler changes, which proves there must have been a problem with the boiler installations in the first place. The estate is only a small one. The british gas service van is never away.
Well, at least you got your free advice. However, you seem unwilling to impart the necessary details that would benefit another novice with the same symptoms.
If you're competent, then fine, but the sad truth is that I've made a mistake in continuing to post on this topic. I thought some sense might come out of you, but clearly I was wrong.
