I am off main sewage, and have a 2 cu m holding tank which is emptied by a grinder pump. After 11 years, the pump died. The company changed the pump and after fitting it, had an Oh Dear! moment. The dedicated circuit for the pump is 10A, and this one apparently, has a higher start current. The fitter suggested sheepishly, a higher rated MCB. (16A type c).
Next problem: my CU is an MK from 1995- all fine, no problems ever. But MCBs are different apparently, and not available...
Question: Can my electrician swop the 10A pump MCB with the 20A garage one (I use diy power tools and a door operner in there) without endangering life or limb? I'd also look for a 16A replacement on ebay, as all the suppliers are suggesting.
Does using a 20A 'endanger' me or the pump?
CG
CG
