You forgot to mention the need for a PRV.Yes it will work provided you use the right type of pump. It will need to be a positive displacement pump in order to create enough vacuum to suck water up the pipe from the well. The maximum height that a suction pump can lift is in theory 10 metres ( atmospheric pressure on the water in the well and a total vacuum in the pipe) but in practise the maximum height is less as a total vacuum on a dry pump is very difficult to achieve.
A foot valve ( one way valve ) at the bottom of the pipe enables the pump to be primed with water ( from a bucket ) before starting so the pump does not run dry.
With the OP using it as he described then it isn`t OEDP.The OEDP pressure relief system does not require a PRV.
( Open Ended Delivery Pipe )
the water to use to irrigate the garden.
Can being the word, back in the real world however ……….Irrigation can be performed by an open ended flexible hose pipe without a spray head.
the hose slips off the connector.Can being the word, back in the real world however ……….
Thanks for the vote of confidence Andy but even an old timer like me doesn`t know it all.I think in this thread we should let Just Pumps have the last word, going by his user name he would have the best opinion.
Andy
