I'm can hearing a clicking sound coming from the boiler pump, its a Grundfos 15-50. The heating pump is the same type and is almost quite. Both seem to be working. Both are on the 2nd setting.
Does the clicking imply its worn or nearing its death?
Is it worth replacing or leaving well alone?
They have been in about 15 years, with no replacement.
Unfortunately the boiler pump is in a virtually impossible position to easily replace. It would require the heating pump to be removed first, and "maybe" some pipework cutting and replacing in front. Can't believe its been installed in such a difficult maintainable position.
I could probably reach the 4 hex screws on the pump body. Would it be feasible to just replace that part? Is it likely a new pump body would fit correctly to this one that is so old?
