Yep, it's looking that way. Would I be right to assume a universal would do the job the same as a negative head? Only issue with those, apart from being about twice the price is that they tend to be taller and so might not fit under the bath.
A universal pump is the new(ish) name for a negative head pump.Would I be right to assume a universal would do the job the same as a negative head?
There shouldn't be any need to, pumps work fine when installed correctly. The trouble here seems to be the install(er), I'm afraid to say.I'm tempted to give up on this and just have them install an electric.
Quick update:
They came back last week with 2 men, removed the bath panel and tested the pump. Nothing wrong with it electrically. Then they reduced the CW flow going into the shower mixer. That allowed the pump to kick in if you briefly crack open the HW tap to the bath. That worked for 2 showers and now doesn't work again.
I don't get why these fixes work for a brief period and then don't work any more. Can anyone explain?
They're coming back tomorrow and have a different shower from another job which they're going to try which sadly doesn't have a rain shower outlet like this one does, just a handset. I'm tempted to give up on this and just have them install an electric.
It's 2m absolute tops at the moment.Have to agree, a pump really shouldn't be under the bath, especially if it's near the max of 4M effective pipe length form the HW cylinder. It all slows the flow down through to the shower, which is what seems to be happening here. (Edit) Ideally It should be sited in the same space and at the bottom of the cylinder.
When it is installed then remember ~ 0.8LPM must flow from either the handset or the rain head under gravity as this starts the pump, if no or < this 0.8LPM then that new shower isnt suitable for that positive head pump possible because the shower non return valve requires a greater head than is provided now. Did water flow under gravity originally from the shower??.It was never right from day 1. We always had to fiddle about with the shower controls to get it to start the pump and then it would fail soon after. Yes, we are aiming to get it replaced under warranty but it was ordered on the builder's account so they supplier will only speak to him due to data protection.
??It looks like the problem could be something nobody thought of! They came back yesterday with a different shower tap unit to test a theory about pressures. This one only has a handset outlet, not one with a rain head as well like the existing one that doesn't work, but not sure that's relevant to the failure identified. They put this one on and it immediately worked.
That was the point I was making, given a rain shower is higher up and has small outlets it needs a higher head of pressure to flow enough for a positive head pump to start. The new shower probably has a higher flow rate with the available pressure, that's enough now to start the pump, that and given that it sounds like they didn't flush the system clean before the pump was connected, that then damaged the old pump, compounding the problem. Gravity systems are notorious for fluctuating pressures and flows, that can play havoc with a pump if the flow is close to its activation pointIf that shower has that rain shower head then they are designed for mains pressure water and need at least 1 bar to operate to any decent degree. Given that is near the ceiling and the CW cistern is just above then you'll be lucky to get any more than 0.1bar of HW at the shower head, at that rate it just isn't going to work properly, there just won't be enough flow to start a positive head pump.
