A while ago there was a post about pump over. It ran over several pages. I cannot remember if the discussion resulted in a solution to pump over problem. What is written below is a similar problem on a real system and it has been resolved. Following is to be an exercise for new entrants to the field of boiler repairs and those who carry out this kind of work everyday. This discussion can be debated in combustion chamber where this post is echoed as well. Finally, if you know the answer, email me if you like confirmation.
Boiler is an old Gloworm wall mounted boiler (the one that uses McLaren gas valve). Return has a Sentinel sediment filter unit fitted to it. Flow runs horizontally with first tee for 22mm vent and second tee (branch 15mm) to feed and expansion tank within specified 150mm distance between vent and feed pipes. The F&E pipe drops to double on itself to rise steadily to header tank. Flow then drops to the floor with pump fitted halfway on the vertical pipe. Pump is a Grunfoss 15/60. System is fully pumped S plan
Boiler is fitted in the garage and F&E cistern is in the loft space above the garage. House is single story bungalow. Vent rises above the header tank by some 400mm to drop down to the header tank. Vent outlet is above cistern water level.
New pump was fitted. Old pump bearings were shot. Pump over started when new pump fitted. Pump set to speed 1 setting
Would anyone like to guess what the problem was? I have to say above setup cannot result in pumpover if plumbing is correct. Plumbing at this house was correct.
No prizes.
No prizes.
