Hi All,
i am a little confused. Until now i beleived that pushfit pipe/connectors did not require a pipe insert. The inserts were only required in the plastic pipe if you used it with a conventional compression fitting.
In posts elsewhere on this forum, i it seems to suggest that plastic pipe to pushfit connector (speedfit was mentioned) requires a pipe insert as well.
i have several speedfit connectors i have installed in my house and have not used any inserts
and nothing leaks (yet???)
can anyone give me the official word as the fella in the brown coat said i didn't need em!! (and he knows everything doesn't he???)
PS. Surely copper pipe to a pushfi connector would not need a pipe insert??
thanks Matt
thanks Matt
