Putty or Silicone ?
19 Apr 2004
Hampshire
Cant find too many mentions of this
I have to replace a small glass pane 30 cm x 33 cm in my garage rear door. I've used putty in the past but with all this wet weather and even though the door is pretty sheltered from the rain I wondered if silicones were a better option ?
The doors are a rosewood/mahogany dark brown and fine a silicone that would be dark enough is quite hard. Any advise appreciated
You can get sealants in a wide variety of colours if you are prepared to.look further than a DIY shed or Screwfix. Try Sealants and Tools Direct as one possible source. They do sealants a wide range of RAL colours, one of which might well be suitable for your job. Yes, not cheap, but not too bad when you consider that putty comes in... oh, 1 colour
glass can be bedded on a low modulus silicone - use low mod, neutral cure or MS polymer
The problem is if the glass needs to be face puttied rather than timber beads
it’s certainly possible to use an acrylic glazing sealant, but it’s tricky to use
Sorry, should have said that I was assuming a hardwood glazing bead with sealant... Does anyone still putty windows in, other than sliding sashes?
Thanks peeps
I did find some putty in dark brown. I am replacing just one pane, out of six, in a back garage door. All the others were originally installed with putty so of course I was focussed on matching. So it never occurred to me to use a hardwood glazing bead. DOH!
I need to check how much space I have to do that but worth checking out. Thanks
You can stain putty to an extent by mixing in oil stain or oil paints. This is because putty contains linseed oil. Personally I wouldn't bother, but I thought it worth a mention as I sometimes use stained putty to fill holes in original timberwork such as oak panelling
I have mixed solvent based mahogany stain in the putty in the past which works ok but it usually needs a few more layers of stain on the top of it to darken it down
