    Dismiss Notice
PVA or just wet these walls for dot and dab?
Discussion in 'Plastering and Rendering' started by Simplez, 11 Aug 2020.
  1. Simplez
    Simplez
    4 Jul 2020
    137
    Thanks Received:
    Country:
    The walls are internal brick leaf - a bit dusty after all the black old plaster was removed.
    What is the best prep before they are dotted and dabbed?
    [​IMG]
    The walls are pretty much like that.
    A bit dusty with some loose mortar in some places.
    To dot and dab on that - should you use 5:1 PVA or just water and dab straight on?
  2. Sponsored Links
  3. sircerebus666
    sircerebus666
    31 Oct 2019
    1,423
    Thanks Received:
    224
    Country:
    Pva them
    Don't forget to leave a gap at the bottom of the wall when you plasterboard and put a continuous bead of adhesive along the bottom so you have something to fix your skirting to
    Do you own a straight edge?
    • Thanks Thanks x 1
    • Like Like x 1
  4. Simplez
    Simplez
    4 Jul 2020
    137
    Thanks Received:
    Country:
    The walls are a bit dusty so PVA them 5:1 and the next day dot and dab.
    Or can you go around the whole house and PVA at once? then dot and dab.
    If the walls are 2.7m high - should we get 2.7m x 1.2m 12.5mm plasterboard or better to use 2.4m? I take it as its being plastered over to get square edge.
    How big a gap should be left at the bottom - the plasterboard should not touch the floor.
  5. 5:1 pva will do it, spray it on with a garden sprayer. in fact the weaker the better , theres sufficient mechanical key on those walls.
    a 1 1/2” gap at the bottom downstairs.
    you don’t really need a gap upstairs , i just pack or space as necessary to get level and plumb.
    i rarely use a continuous adhesive at the bottom ,as it can tend to cause more mess than its worth and stop you getting your packers out. when i’m done my walls are perfectly flat meaning my skirtings can be bonded on easily.
    • Thanks Thanks x 2
  6. Simplez
    Simplez
    4 Jul 2020
    137
    Thanks Received:
    Country:
    Spray it on and leave it for a day and then crack on with the dotting and dabbing.
  7. yep
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
