Hi all
First time poster here, would greatly appreciate your advice.
I need to remove my PVC door for a delivery (after which hopefully I will simply put it back as it was). I've opened the door 45 degrees but it will not lift up! I feel like I will break it if I apply more upward pressure.
I believe this is a flag hinge (pics below). I can open the casing of the hinge on one of my other identical doors (not the one I want to remove) but on the door I am trying to remove I cannot a. remove this casing or b. lift up the door. I'm posting the pic of the inside of the casing on the other door in case it helps.
