I have install a Pyronix 32 and all is working well. I have set up 5 tags for exit and entry having the front door as the exit / entry point and count down timer.
I've noticed that a tag can be used to turn off the alarm once it is triggered and i am concerned that sometimes a key and key fob is left in the building so the alarm could be silenced if somebody uses the tag.
I see in the manual that you can set for key fob that the alarm can only be disarmed if using the entry exit point during the count down timer
" Fob unset Entry - A fob can be used to unset the panel only if the entry time is running"
I have tried this but it does not work and i assume this only work for key fob and not tag.
Any ideas or is this not possible for the tag.
