Pyronix Enforcer V11 trouble setting zone D
26 Apr 2025
So we have 3 door contacts (back/front/side); I am wanting to create a zone D so that we can set just the door contacts.
So far I’ve learnt them to the alarm and added them to zone D with the input 07 final exit. The setting timer is set to ‘timed’ however, whenever I put in the user code to set zone D, is doesn’t give me the option. The D button doesn’t even light up. What am I doing wrong?
Thanks, help is appreciated
Ahh I see, would you mind breaking that down in steps (I’m not overall great with this kind of thing). Thank you!
What do I need to edit user to? And do I need to do this for all zone now or just D (as the door contacts are in all zones). Thanks
When your in the edit user screen you’ll be asked to assign what zones A through D each user can set and unset. If your saying the user cant currently select D then you haven’t chosen it to be possible in the user setup.
You need to set each user with what zones you want them to be able to use
Ahh I see, I’ll give this a go. Is this under the engineer settings?
When you say ‘user’ I’m presuming that’s by inputting the user code? If that’s the case, there’s only 1 user and 1 user code.
Push D enter your master manager, not your engineer code. If you only have 1 code it might be this.
Select no through to edit users, choose the user needing amended, again there may only be one, select no and scroll through to where the zones for the user are shown / illuminated and amend as necessary
