Pyronix SEB Tamper
How do want to wire pir?
Jumpers off for traditional wiring or Jumpers on for EOL 4k7 & 2k2
This is a picture of the options listed on the instructions and I'm going to post a picture of the option I have used which is showing a fault.
That's the correct wiring diagram for EOL
wire as that and check jumpers are on 4k7 and 2k2
Mmm... So can I place the red and black to Auxiliary 12v power on the panel as I didn't know which connections I would put the red and black on the board as they are marked (Input 1) A and T?
Just for your reference, the keypad says 'Tamper on Input' if that helps?
On your control panel you have +12v & Ov
These are the power terminals for the detectors.
A A & T T are the zone connections
So
A EOL and T com are the terminals for the EOL connection from the pir
Keypad display is telling me not wired correctly.
Post photo of control panel wiring
It's input 1 i'm using, input 2 is the door contact from earlier.
That looks correct.
Can you go into engineering programming
Press NO until you get to DIAGNOSTICS
Press yes
Wireless devices No
Wired Devices yes
View inputs yes
Endstation input Yes
Post photo of keypad display
If all çccccccc then OK
If occccccc then issue
