- Joined
- 15 Nov 2005
- Messages
- 132
- Reaction score
- 1
- Country
Hi
Our dining room had a glazed opening through to the sitting room. I think it must have been retro fitted to the house to let some light through. We hated it so at the weekend I started a project to remove it and I'm now left with a chunky wooden sill, two chunky wooden uprights (1 on each side) and a chunky wooden "lintel".
Now, the plan is to put 4 vertical box sections into this gap to create 5 slits in the wall which we can then place candles and ornaments into. It should look a bit more modern yet still allow light through and provide some division between the rooms.
Now, with the glass removed I'm wondering if I might make the opening a little larger. The easiest thing to do is going to be to remove the existing wood and replace it all with thinner plasterboard. The uprights and lintel are 25mm thick each so that would give me an extra 32mm width using 9mm board (2 x 25 - 2 x 9).
The sill is 40mm thick so I'd get an extra 47mm in height.
Here's the question: are those bits of wood likely to be providing some kind of support to the surrounding plasterboard or is it simply a tidy way of creating the box into which the window was installed? The pieces appear to be screwed into place which suggests that there are beams inside the wall anyway.
Doing this will also make the plasterers job easier rather than trying to plaster onto hardwood.
