Q Re. Power through coax to Masthead amplifier
6 Nov 2004
I have a masthead amplifier on the TV aerial that is fed in the normal way via a PSU and coax cable from behind one of the TV's. Next week I am having new windows installed and the "powerback" coax cable which goes through the old window frame will be the devil's own job to remove unharmed.
So could I simply cut the coax cable near the PSU fit a male connector and rejoin it to the old cable routed in behind the new window frame, with a male connector fitted and join via a simple female connector ?
Or will it be "live" ! Are there any connectors designed for this purpose ?
What other options would you suggest ?
Thanks John
You have 12V and low current (<0.5A) running through the cable. There's no risk of electrocution to you.
The only thing I would say is that you really should switch off the power supply before doing any disconnection or cutting of the cable. Not for your safety, but to avoid shorting out the power supply.
Connections in coax cable are best made with F connectors on the end of each cable, then an F-to-F back-to-back connector. Here's a link to the three bits shown together, but this one is for a thinner cable. You need F connectors for RG6 / WF100 sized cable which is about 6.7~6.9mm diameter. The back-to-back connector is the same size regardless of the size of the F connector size used for aerial/satellite work.
These plugs aren't waterproof. So make any connection indoors. TBH though, most masthead amp power supplies don't have captive aerial cables. So you should be able to disconnect the aerial cable from the amp, remove the plug, and thread the cable back through the hole in a reverse of how it was installed. This is potentially simpler so long as the cable isn't painted or too stiff.
Thanks Chris - most helpful. John
