I needed to fit a new immersion heater as the original 35 year old one had died a few years ago and I want to cut down on use of gas. The system is a Baxi gas boiler feeding the indirect hot tank via its internal heat exchange coil. Both the hot water tank and the heating system have their own cold water header cisterns in the attic.
I turned off the cold water feed to the hot tank and run all the hot taps until they ran dry. The cold water valve was VERY stiff to turn at first.
I then removed the immersion heater from the top of the tank and was surprised to find that the tank was filling slowly with water and started to overflow .. I could not get any further turn on the cold water feed valves so I had to work very quickly and get the new immerser in place.
All is working again OK but I am very concerned that the slow feed of water to the hot tank may be due to a leaking heat exchanger coil in the heating circuit.
Can anyone advise on this ? How could I investigate this possibility? I thought of putting some intense coloured dye in the heating header tank and seeing if the colour came through to the hot water taps circuit.
Any advise appreciated
IanR
IanR
