We have a house with a detached out building that has a water supply pipe emerging from the concrete floor. The pipe comes out the ground in copper and has a stop tap then it changes to plastic. (approx 0.5m copper). There is no bonding attached to this pipe.
Electrics supplied from the house are present within the out building. The feed to the outbuilding is a 4mm ² PVC 2core SWA cable. (armouring used a cpc).
The earthing arrangement for the property is tns.
When carrying out an EICR, what code, if any would you assign to this? Also if this fails to comply with BS7671, what methods could be used to achieve compliance?
I have my own thoughts on this. Interested to here others.
