Looks like the battery needs to be changed in the room thermostat. Two AA are required.
Did the battery sign (top right) disappear when you put in the "new" ones? If it didn't you need new batteries.Yeah we used two from the tv remote but it didn't make a change
If you mean the boiler goes out, this is because the water in the boiler has reached the set temperature; it has nothing to do with the house reaching temperature. You adjust the boiler water temperature by turning the right hand knob; try turning it fully clockwise.i have noticed that even if i set the stat to 24 or 25 the flame goes out when it reaches about 21-22. this surely cant be normal?
So if that was to happen how would I get it fixed again or is it gone forever then
Also I turnt the heating off as the pressure went to 3 now its dropped to 1.5
