Hi all,
I'm having a bit of a reconfiguration and am wondering on noise insulation on the walls around a downstairs shower room/toilet that is in the process of being built. Its only approx 1mx3m. The room borders four different other rooms, but it is the walls adjacent to (1) the hall and (2) the lounge that I have questions.
I do understand that noise insulation is quite complicated and to be done right might need quite a number of things for the best result - but I'm trying to make the best of what is available here so can't go lock stock on the matter.
The wall to the lounge is mostly brick or breeze block but one portion is an old door which has been closed using studwork. My question on this whether you would get better noise insulation from (a) studwork with some Rockwool RW5 (or similar), acoustic plasterboard on one side, standard on the other or (b) breeze block with acoustic plasterboard on one side, standard on the other.
For the wall to the lounge, this is studwork although I can make it a bit deeper (i.e. more than 4inch studs) to get more insulation in and could double board in on the toilet side. Does anyone know which level of noise insulation rockwool (RWA 45 or RW3 or RW5) is best at absorbing 'noises associated with a person visiting the toilet'?
Cheers for any advice!
