D
dextrous
ok so the supply from a combi is 15mm.
i would as soon as practicable after the boiler,increase the pipe to 22mm to feed all hot water outlets in property.
Not being a heating engineer, I wonder about this - the boiler can only heat a given amount of water over a given time, so why would an increase of pipe diameter improve the bath-fill time if the available flow rate is the same? Apart from that, what about 22mm requiring 4 times the amiunt of water displacement than 15mm before hot water gets to the outlet, and the amount of heat loss when that tap is closed and this heated water in the pipe isn't used
My mistake- just seemed to be going in circles until you explained.and i am not taking the p iss
