Quick question about a rainwater pipe
6 Jul 2008
London
Hi, I'm pretty useless at this but I have a cast iron rain water pipe as per the pic which has the bend part at the bottom. I wanted to connect this to a upvc pipe (as per the brown pic) and I wasn't sure what sort of connector I would need. Both pipes are 68mm and I can only seem to find adaptors for 110mm. Could anyone suggest something, I need to try and source it by tomorrow. Thanks all
Most plumber/builders merchants should have a stock of these.
Even at some of the sheds they can be found,
ask for downpipe connectors, bends, adaptors etc..
Thanks very much or your reply. I managed to locate a flexible coupling which I think will do the trick.
