Hi
I'm in the process of changing the CU in my house.
On disconnecting the mains cct I found 2 cables into the same fuse which i thought was a ring cct but when I tested I had no continuety between the live cables, so I suspect that there are 2 seperate radial ccts!
Can I move these to the new CU or do I have to convert to ring.
These ccts are both on 2.5mm cable.
