Bung the system dont no what you mean,
I only want to move the rad to do a 30min job
thats why i would bung the system rather than drain it.
you could be there another day filling and getting airlocks out.
bung the system is where you block the vent pipe and feed pipe.
so when you start to drain the system you only get a cup or two of water out and its stops a the bungs have created a vaccum.
they are useally a square rather than a allen key.do you know what size allen key it that will fit the drain plug as the look like they have not been touched in years , is it more likely to metric or imperial.
If i have a dodgy valve that is not shutting is more likely to be the lockshield as i can fully tighten and close the manual valve with a spanner.
could be any one of them.
