someone was doing star jumps in their bathroom once
Not really.I thought that when the 17th came in, and effectivly lighting circuits were RCD protected, the bonding requirement was reduced
Other than in an existing bathroom installation which is not RCD protected?Supplementary bonding "May be omitted" is not really the correct term to use. It is never going to be necessary.
Not really.
It's just that with RCDs (plus the other two conditions) R ≤ 50/Ia is never NOT going to be the case.
Sorry - although it's not too obvious from your quote of yourself, the original was clearly two separate paragraphs, and I thought the second one was intended as a separate, general, comment, rather than actually being 'part of the first paragraph'.I don't understand. I was talking about with RCDs.
A multimeter is only good for a very rough test of earth continuity. An Earth Loop Impedance tester is what is needed, to measure the low value of resistances involved with some current applied.
What else is required to determine whether bonding is required or not?
That makes no sense.
So if my multimeter, set to ohms, detects good continuity between the pipes, I can forget about bonding?
Are people talking at crossed-purposes?A multimeter is only good for a very rough test of earth continuity. An Earth Loop Impedance tester is what is needed, to measure the low value of resistances involved with some current applied.
OP was talking about measuring the continuity between his radiator pipes with a multimeter.Not sure.
What isn't?It's not the correct test to determine whether bonding is required anyway.
I understand that bonding is to get two bits of metal, within arms reach, to the same voltage if there's a fault so I suppose someone sitting on a radiator using a hair dryer which
There will be, won't there? They are both connected to the radiator.
They are both connected to the radiator.Not necessarily, there could be plastic pipes in the plumbing network.
