Hi all,
These few days, finding the radiator hot. The programmer shows CH OFF. Checking the mid-position valve (with A3MID Acuator head) finds that the pipe to the radiator (connecting to Port B) is hot.
Removing the cover of the head so I can see the motor, springs, etc. and did the following:
(1) I turned off the power (of the entire house, as not sure which switch is for the main system controlling the boiler/heating system. Is it the one near the Programmer). Follow the tips given at: http://www.diynot.com/forums/viewtopic.php?t=287357, by pushing the lever below the actuator across the slot, it seems hat the the valve is not sticky.
(2) Got the partner to turn on/off power while I was watching the Acuator head. No single slight movement seen or heard. From the Programmer, On/Off both/either HW or CH seems not 'activating' the head at all.
So, problem with the Acuator? Advice further check such as electric test (using meter)?
Thanks.
Thanks.
