hi everyone,
a single radiator in the bedroom has been making this intermittent tapping sort of noise. it makes a single tap noise and will stop and then it will happen again intermittenly (might be every 5-10min). this carries on as long as heating is on so all day.
To be clear, am not referring to the usual tick tick tick noise when the heating comes on and you have the metal expanding with a ticking noise.
this one is from only the bedroom rad. its also intermittent and might do it every 5 or 10 min when heating is on. the rad has a TRV on it.
anyone has any idea what might be causing this? could this be the valve on either side of rad causing this noise? noise is certainly from the rad itself. noise is somewhat like tapping the rad with a metal object. No noises from the valves themselves.
any advice welcome and thank you
