- Joined
- 16 Apr 2017
- Messages
- 7
- Reaction score
- 0
- Country
Ok, I moved into house seven weeks ago and after the oil delivery chap had bled the system from the external boiler, all was working fine. As not all the rooms needed to be heated, plus oil being a bit expensive, I thought I'd turn off some of the radiators. I now need one of them back on, but no heat!!
They have the old valves, need a pair of pliers to turn them on and off. I had an awful job to turn them off, but now the valves won't budge. I thought I'd cracked it earlier, but I'm not sure if I've turned the correct valve round. And before anyone asks, no, I can't remember which one I used to turn each one off. One of them is very scratched, so I thought it was that one, but it won't move, whereas the other one will.
Any ideas what may have happened? And the pipes under the valve I did manage to turn is freezing, whereas the other one is just coldish.
