I am having a problem with radiators in my flat that i moved into recently. Since the cold weather kicked in i have been using them quite a bit. At 1st if i wanted to get any heat from them i had to have the thermostatic valve turned to 3 1/2 - no heat would come from them otherwise. this was fine cos it kept the rooms to a good temp.
yesterday i had the heating turned up to 5 (full) as some elderly relatives were coming round. Now my radiators wont heat up unless i turn them to 4 1/2 or 5. the radiator in my hall does not have a thermostatic valve and is roasting all the time. Ive tried bleeding the radiators but water comes out straight away! Im stuck!
Any advice would be greatly apprciated...
ps meant to say. i have a potterton combi 80 boiler.
