Radiator schoolboy error!!
21 Oct 2011
West Glamorgan
I've just spent a couple of hours fitting a new radiator. I fitted the brackets and then spent a frustrating twenty minutes attempting to hang the radiator on them. Once it was hanging the connections lined up beautifully. I filled and leak tested the radiator without a hitch. As I was standing back to admire my work I noticed that one end of the rad was half an inch closer to the wall than the other end. You guessed it: I'd fitted one of the brackets the wrong way round!! My question is this: Is there any need for me to take the rad off and change the bracket round (apart from cosmetic reasons)?I can live with it the way it is and so can my wife.
Top tip Terence!! :-)
What I will say is that the rad is fitted to the wall that the bedroom door opens onto, so you won't see the narrow end of the radiator most of the time as the door will be against it. I'm tempted to change it but the fact that the rest of the job went without a hitch is making me reluctant to mess around with it. What if I have problems lining the connections up or it leaks?
:shock: :shock:
Lift it off the bracket so the rad is off the wall the same distance as the other side and support with a few books or a couple of bricks , job done.
purely cosmetic, i'd change it, but that's just me, i freak out in customers houses if pictures are hanging squint and have to restrain myself from straightening them!
