Radiator tail to shut off - metric to imperial
26 Mar 2006
Aberdeen
Hi all,
Can anyone recommend suggestions on what i can do here?
I'm replacing an old radiator in my house with a new one. The old radiator shut off valve is an imperial size (1" external - photo attached), then the tail from my new radiator is metric (15mm tail - photo attached).
I'm looking for a quick fix (not ideal but have visitors arriving Thursday and need the room finished). Do you get a tail for a new radiator that goes to an imperial shut off?
I would have replaced the shut off valve...but the pipe's painted all the way up and I'm concerned i don't get the new one to seal properly...I would have replace the last leg of pipe, but I'd need to cut an access hatch in the floor for that. So that's a battle for another day.
Any help would be appreciated!
Cheers
Perfect mate, thanks very much! I'll get one today and try it out.
Cheers
Cheers guys...that's worked perfectly!
Noticed the need for large allen key after i got home!! I improvised by using a bolt head where I'd filed the shaft square :)
