RANGE POWERMAX 155X POTTERTON CLOCK / TIMER PROBLEM
27 Dec 2006
Hi
Have got a problem with timer / clock display has disappeared.
Have no central heating but do have hot water only.
Is there any way to switch central heating on or is the timer / clock the only way it can be switched on???
Is a replacement clock timer the answer or is the reason the clock
display dissapeared a problem elsewhere in the boiler circuit?
Does anyone know the model no. for the Horstmann timer (P458)
and is it easy to fit?
sorry if this is a repeated message as i could not find the previous post i sent??
thanks alistair
not the best clocks in the world you answered your own question model number is p458 :D
i doubt if it works but you could try reseting the clock by holding all the buttons in together for about 5 secs :?
Thanks for reply would you know if the clocks are easy to fit??
alistair
not the easiest as the surround around them has to come out at an angle bit of a puzzle the first time you do one but doddle the next ? :?
Holding the second and fourth button is the reset Gaz:!:
Still works if you hold all of them in :)
Still works if you hold all of them in :)[/quote]
Or not! as the case is normally :P
Can i just pik ya brains on these 155x. never had anything to do with them yet but they get a lota bad press on here, got a customer whos buying 2 x 3yrold houses to rent out & they both have these. Whats the script on service as both have no instuctions or history with them. I will need to give a landlord certificate for both in the new year Dont want to go in blind.
You just need to follow the instructions for the full service to be carried out every two years. Will need a fga, probably a full set of turbulator baffles and a gasket set and will need a good 4 hours for your first one.
I guess baxi/pot will do this on request. the problem is there 20miles from me & dont want to get sucked into call outs if there problematic. but do a lot of work for the company.(Specialist jo ehh :wink: :wink: :lol: )
bab said:
I guess baxi/pot will do this on request. the problem is there 20miles from me & dont want to get sucked into call outs: )
What do you mean?
Are you talking about Heateam?
